Ok I'm reinstalling my freshly O-ringed head in just a few short hours. So far these are the only TQ specs I've been able to find close to my year model through the search feature.
Can anyone tell me if this is correct?
:{ Seems like everytime I've SPOKEN with someone I've heard 90ft/lbs + 90*
Also what about the rocker arm retainer bolts? What do they need to be torqued to?
TIA!
Try the service manual. Other wise do this:
Number the head bolts on drivers side starting at rear: 26, 22,18, 14, 10,6, 2, 3, 7, 11, 15, 19, 23. On pass. side starting at rear: 25, 21, 17, 13, 9, 5, 1, 4, 8, 12, 16, 20, 24.
1) Tighten al bolts in sequence to 66 ft lbs. Check the torque. If lower than 66, tighten to 66.
2) Tighten all long 12mm bolts (nos. 4, 5, 12, 13, 20 and 21) in sequence, to 89 ft lbs. Check the torque. If lower than 89, tighten to 89.
3) Tighten all bolts , in sequence, and additional 90 degrees.
The above is from the 1995 service manual.
TIA!
