I am using a slide hammer with an adapter I made which spans across two studs. I am holding the adapter on with lug nuts and the slide hammer is screwed into the center of the adapter so I am pulling from the center of the hub. I've been hammering for about 10-15 minutes and it has barely moved.
Is there another trick to get these off?
I removed the 4 bolts from the back of the hub and the spindle nut and the caliper is hanging by wire from the frame . I don't think there is any thing else I have to take off,is there?
Any body have any other tricks, I need to get these off today?
Thanks.
Jerry
Thanks.
Jerry
