HELP!
I started my truck this afternoon when I was going to go into town, and as I started backing down my driveway, I found no power steering assist and no power brakes. The pump was moaning like crazy when I tried turning or braking, and when I went to check the power steering fluid level, it was puking out from the cap on the reservoir. Since I had just read a post on here the day before about the nitrogen accumulator going bad, I figured that was my problem.
However, isn't the fluid puking a one time thing? I shut the truck off and let the fluid finish foaming and spilling out, then checked the level--it was ok--then started up again and performed the preliminary tests listed in the service manual (holding the brake when starting, etc. ) and the fluid started spilling out again. After topping off the reservior and driving around a little bit, it is still foaming and puking, and my steering and braking are mostly without power assist. Any suggestions before I take the Hydroboost module out and pay for it to be rebuilt?
If it isn't one thing, its another
Thanks,
CTD12V
Thanks,
CTD12V
