2nd Gen Non-Engine/Transmission HELP...Rough Ride and Vibration
2nd Gen Non-Engine/Transmission What is it worth?
Engine/Transmission (1994 - 1998) 12V Cam Core
I need some help diagnosing a problem I am having. I have a miserable ride and lots of floorboard vibration. I can hear and feel every little bump in the road and the floorboard where your foot sets vibrates. When I hit a bigger bump I get stutter in the front end.
Alright now for a little background of my problem. I put a buckstop bumper, leveling kit, and rancho 5000 shocks on in September and have about 5000 miles on them. I also have BFG AT 285/75-16 with about 15000 to 20000 miles on them. I had it aligned after the install of the leveling kit and they set these numbers. LEFT side Camber 0. 1, Caster 2. 7, and Toe 0. 04 RIGHT side Camber 0. 1, Caster 3. 0, and Toe 0. 06 .
I have tried a few things which include I tightened up the bottom shock bolts, any more and they will break. This helped a bit. This weekend I checked over every bolt underneath. The only thing I found was two slightly loose upper control arm bolts, both on the same arm, and both I tightened up. It didn't help.
I have the vibration all the time while on the road. It feels like the tire boucing on the road. It gets better or worse dependent on how rough the road is. But is there some all the time. I have it with the transmission in neutral coasting, clutch in and out, it doesn't matter. I'm thinking that the ranchos are junk but I need some opinions before I go spend money on new shocks. I'm thinking some bilstiens. I think I may also have a tire issue?
I really need some help with this guys so any response would be much appreciated.
Vibes.
I experienced similiar vibes when I had the exact same BFG tires installed on my '99. I returned to Discount Tire numerous times for road force and dynamic balancings to no avail. The balance guys showed me where they"zeroed" out the tires. The vibes prevailed until out of desperation,I purchased some Toyos of the same size. Guess what? Problem solved! Smooth as glass. Hope this helps. BFG's are real popular and are used on the Powerwagons,but they didn't work out in my case.
When I had a vibration that I could not locate, I had Les Schaub rotate the tires on the front rims. (They broke the bread and rotated the tires 1/4 turn. )Problem was gone.
