The first time I tried to change the belt on my '92 I had a HORRIBLE time getting the new one on! Later a friend told me a trick that has really helped. Remove the top alternator bolt and loosen the bottom so it can pivot. It will rotate toward the motor effectively reducing the needed belt length... making it easier to install the belt. After you get the belt all the way on, you can pry the alternator back into place and reinstall and tighten the bolts. Hope this saves someone some grief.
Steve
