Help!!! Speedometer pinion drive gear piece
93 o.e.m trans lines and door sill plates
Post ONLY IF You have Info Or "Work Arounds" On Discontinued Parts/Sources
I am in great need of a pinion drive gear that is located on the 1st gen NP205 transfer cases. This part couples the speedometer gear ratio reducer to the transfer case. Mine is worn out and the dealership said they are discontinued. The part #: 4329816 (16 splined teeth)
Sorry, just checked the link above, they show out of stock on these. The address I typed above was to "transmissioncenter.net" and the link spit that out? I guess you'll have to search on 4x4 sites for a drive for a 205 New Process transfer case.
