jimmyivy said:what is a good mod. with a superchip programer? fuel, timing, what? what does a superchip programer do? fuel, timing or both? i have 99 2500 with intake and exhaust mod.
Diesel Nut said:Your Superchips does Timing, so you have to be aware of that when deciding wether or not to stack it. 275RV injectors are a great choice, or like posted, a set of 3 flows from Industrial. And Edge EZ might not be a bad stack, but first you need to think about the important stuff - gauges, gauges and gauges.
Oh, and you need gauges!
Fill out your sig so we can see what you have.
If you have not installed gauges you NEED a Pyro and Fuel pressure at the absolute minimum. I would add a boost gauge and throw in a triple pod and mount it to the A pillar. With that done you can judge if you are ready for more power or if you have more work to do (AKA lift pump).
jimmyivy said:i am a little confused about superchips???i am getting gauges, i know that you can not get power from the same place twice, so i was looking to get rid of the superchip and get edge juice with attitude b/c of the gauge pod and hp-torque increase. i have boost fooler and elbow but have not installed it, i also have a AT with triple torque and hd valve body. i am trying to put all of this on my signature. but since i have not the time or the funds to buy all and try all, i have to be choosey. is doing away with the superchip and starting over better (b/c i need a monitoring system anyway)or just adding injectors with a boost fooler and elbow?
