Brought my 99' in to the dealer for the typical oil leak that runs down and collects at the bottom of the trans. bellhousing. I point out that there is drops of oil on the back oil pan bolts. Thay are telling me that they have to replace the pan gasket... . ok, I can buy that. They also tell me that my rear main seal is leaking too. I dont buy that!! No evidence of oil inside the torque converter inspection cover area and nothing coming from the center area between the trans and motor. They say that the transmission has to be pulled to get to either gasket. Can the oil pan be removed without having to pull the trans out?? This is some major work by idiots I really dont trust. Do you think they would have cleaned things up and tried retorqueing the pan bolts first... . Nooooo!! That is the first thing I'm going to do. Any advice???
