Archived HELP... The Ole' Dies -Starts -Won't Start - Starts...
Archived 3rd Gen, front drive shaft removal
Archived New York transmission Rebuilder
Okay - just bought a '96 in Denver - Drove it to Houston (Clear Lake) with 0 problems :)(well - it looks like the compressor went out on the A/C but I question that:rolleyes:).
Now this is a work truck and I am being told it would run strong - die... start right up. Was doing this for a day or so and now nothing...
No fuel "at injector"... the guy driving it is telling me a diesel mechanic cracked the fuel line at the "top of the motor":confused:?
If it were the injector wouldn't it have lost power and ran bad before going out? He said it ran fine but would just die going down the road - starved for fuel I know.
Told my driver there was no suction at the tank with the cap off... ???
Please help and if you know of a good source in the Houston area I would appreciate it (oh and a good Colorado attorney would be great :mad::-{}:mad:#@$%!)
Theres a list , fuel pressure test , lift pump , fuel filter , overflow valve , leaking fuel lines - lift pump forward look for fuel leaks with a flash lite & mirror , lift pump back - suction / so no fuel - put 3 lbs air pressure in fuel tank to check for leaks , fuel shut off solenoid -may be out of adjustment -maybe bad - or relay that controls it - tie the linkage in the up position [ this might be the 1st thing to look at .
Email me at -- email address removed -- for my write up on the fuel supply system, how it works and how to fix it.
Towed away...
With my time restraints I am going to have to have it looked at - many of you know about HotRodDiesels, Your Houston/Galveston Diesel Performance Headquarters out of Hitchcock, TX. It is being towed there :{ and I will let you know the prognosis ASAP.
Thanks for your replies. This site has saved me thou$ands I know - guess its time to give some back. :cool:
I have known about them for a while but never needed them... but when you have no time and a lot of knowhow... well you really get nowhere fast.
I spoke with Micheal there and these guys really seem to be an honest and upright business... THANKS MICHEAL! Glad to do business with you. ;)
I will let you guys know... and for future TDR members who may run into the same thing.
So far - replaced the Fuel Shut-Off Silly-Noid (Solenoid)... that got the truck up and running again.
Now there may be some other issues because of mileage while towing 10-15k lbs.
We are going to have a Gov. Spring Kit install - reset the timing - Set the valves - and put the KDP in check and of course new front seals. All for about $1000.
I would like to put out an extremly big Thank you to Micheal at Hot Rod Diesel... what a great guy to work with. If you are in the Houston area - you should give him a "working" visit. He really knows how to work with people and do right by them.
Anyway - so far - Fuel Shut-Off Solenoid... fixed!
