(Help) TPS
High Altitude Starting Problem
just joined
bad news
When I needed 1 for my 93 (about 4 years ago), the ONLY place that could get one is the dealer. Back then it cost 200+ dollars. Hopefully someone knows of an aftermarket source for you.
simon
Throttle sensor fix!!
I don't know what your problem is, but when my TPS acted up,transmission was seaching for a shift, I took off the TPS and washed it out with contact cleaner, working fine now for about a year. You can spray contact cleaner real heavy inside where the shaft comes out of the sensor. Take a wide blade screwdriver and turn it back and forth, flush it out again and you should be fine... .
FYI
I got the TPS for my '92 from Cummins for About $138 last year. Just take the part number off the TPS and your engine CPL and give your nearest Cummins dealer a call.
Jeremy
