Noticed some smoke coming from under hood,so i killed engine,opened hood and checked. Was coming from the two wires going into the top of a little canister down under the fuel filter. Not the fuel filter itself,but below that,it looks as if it's attached to the same bracket (just in front of) where the primer pump is. So I disconnected the connector from the harness,and fired it up. No more smoke,and it ran ok so i carried on and it quit about a min later and would not restart. It would sputter and cough a bit,but now nothing. Tried priming it (from the air bleed on filter outlet) and all i get is frothy fuel just full of air. Thought maybe it was out of gas (damn broken sending unit),but have put in 5 gals,and still nothing. Pulled fuel line coming from tank (at rear of intake) and none came out,but i could siphon it up with a vac pump. Could this little fire at what i think is the fuel heater have burned a hole into it and caused an air leak ? I have no fuel leakage there though. I can only see one line going into it (from the tank),and none coming out. I assume it must feed through some internal passage to the primer,and then i can see another large line coming back up the the fuel filter. I have also pulled this one off,and get no fuel when i try to prime it. There is also a large rubber line that goes from the top of this little canister,over to the primer. I checked for fuel and any sort of pressure there and there is none,although i think it is not fuel system line. Now i'm stuck. Is there any way to get this thing bypassed to see if that is the problem,and to get it back to my shop ? Which brings up one more question,where is the lfit pump ?I am assuming it is all part of the primer assy ? So if i did bypass it it would probably not work,as i am bypassing the lift pump also ? Is this correct ? Please help. Thanks in advance.
