On the way home from work, cruising at 45mph, Truck sputtered a couple of times then just died. I dead sticked into the local Shamrock here in Falcon, CO. Won't start at all. Bumped the starter and the lift pump is making the normal noise (not sure that indicates it is good). Unfortunately, I didn't learn my lesson the last time the LP went out and still don't have a fuel pressure gauge.
ColordoKing is coming over in an hour or so to give me a tow home and I'll hook up the SuperChip and read codes. I carry a spare fuel filter so I thought I'd try that also.
Crossing my fingers that it isn't the VP44. Anyway to check it? Crack fuel lines and bump starter?
Couple of days ago I went to start it and it just "bumped" like the batteries were low or the starter was out. Fired fine on the second try. Cleaned the battery cables and checked alternator output this weekend. Alternator putting out 14+ vdc consistently.
Any thoughts. I'll post codes (if any) later when I get my truck home.
Thanks folks.
Cheers,
Gunny
Thanks folks.
Cheers,
Gunny
