Engine/Transmission (1998.5 - 2002) HELP! truck dies at idle, need to take truck to piers tuesday
Engine/Transmission (1994 - 1998) '98 12 valve, ISB block and what else?
C
2nd Gen Non-Engine/Transmission Can price - 97?
truck has been dying when i pull up to a stop sign. Does not want to start up again also. when i pull a little grade or go down small grade does same problem. Also when at idle for a while it wants to die and picks back up. Thought it was fuel line in tank, so jrobinson1, doc cullen, and i changed the entire fuel system to a 1/2" fuel system, from inside tank to vp 44. Left the professors place and truck died at the stop sign. Also truck does not throw a code, ... ... ..... help please any suggestions will be appreciated, ... thanx, ... reb
Guessing that you already checked your fuel pressure ? I've been through 3 Mallory pumps, they don't last IMHO.
Scott W.
Does your tach bounce when the engine dies?
Your sign does not say what year your truck is.
Your symptoms sound pretty much like a faulty Crankshaft or Camshaft sensor.
Depending what year model your truck is...
From 2001. 5 the Crank sensor is no longer used.
Marco
the truck is a 99. I had a bouncy idle about twenty thousand miles ago and i thought it was the crank sencor, and it was. I changed it and truck ran fine. Now everything works great, does'nt throw a code, but every once in a while, and the code does'nt last long enough to get it checked. I'm gonna order a cam sensor and maybe a throttle sensor and see what happens. What does the cam sensor do on a 99 truck? thanx again, reb
Crank sensor
The Crankshaft sensor on the '99 is used for engine speed and engine timing purposes. A faulty sensor and the truck will die @ idle speeds.
Have had the same problem here. The connections to the Cranksensor were faulty ( oxidation ) the code wouldn't last long enough to read it.
Marco
