HI Guys,
I was driving my work truck today ( A 1997 Freightliner MT 45 step van , Cummins 5.9 , 4 speed allison automatic, 3.3 Rear, 19K gvw, 272 K miles ) and it continues to lay down smoke (I hate to say it looks kinda bluish but the truck does NOT regularly burn oil) even when warmed up (temp gauge about 200 degrees, oil pressure a min of about 40-45 PSI at idle....Hard to say how accurate gauges are ) and only pressing mildly on the accelerator.
Outside temps probably upper 20's to low 30's
The truck is not loaded heavy (I only haul high bulk snack chips, cakes and some candy)....not even full loaded
Anyways, the truck typically smokes and misses / stumbles when cold (the smoke looks whitish upon start up, clears up after loping at idle for awhile (or if I push the accelerator the engine will speed up but then lay down grayish / white smoke after the engine reaches a certain RPM then it kinda feels like it is missing (the engine kinda "chugs" when it is acting up (almost like a gasser when it misses)).
FWIW - I realize that this Freightliner truck has NO heater grid and was NOT plugged in BUT my other truck w/ the 5.9 has inoperative heater grids and it does NOT lay down white / gray smoke like this one even in the cold when cold...Heck the other truck never "chugged" or stumbled even when only warmed up for a minute before gently driving off.
I know generally what the different colors of smoke means (white / gray - cold start , blue is oil burning, black is unburnt diesel) BUT what I can't figure out is the "missing" feel I get when I try to accelerate (the smoke only happens when the engine "chugs" or "misses").
In the past , I have had this problem before (interesting to note this only used to happening colder weather when the engine was cold BUT it it used to go away once the engine warmed up a little bit) BUT now (actually tonight) the engine came be up to temp and it feels like it still misses and will lay down a haze (hard to tell what color since it was dark out...I could see the smoke by the side mirrors and the headlights of the cars behind me) when driving easy....
Worse part was it did it this slight "miss" and haze the rest of the way home and now I'm worried I may not be able to use the truck for work tomorrow
I bought the truck used so I don't know the history of the injectors / injection pump etc...
I have changed oil regularly and every once in awhile some power service fuel additive.
Are there any tricks of the trade to figuring out what is wrong?
(the fuel filter was changed about 7 months ago....The truck is driven about 325 miles per week)....I just drove the truck the other day about 180 miles and it did exhibit some of the similar symptoms but not the more continuous "missing" that happened tonight (FWIW the truck got 10.3 MPG on the highway which is lower than when I first got it BUT I realize now is winter and the fuel may not be as good) ?
I may try to do a video tomorrow AM of the start up and chugging if that will help ( I can maybe put it on You Tube).
Thanks in advance for any and all help.
Andrew
PS - Is there anything horribly wrong (other than pollution / possibly breaking down ) of driving the truck like this (at least until I finish my work)....I really have to work BUT I don't want to damage anything and cost even more to fix.
Andrew
