Ok, so i just adjusted my APPS and when i started my truck to work on it before I did it had a weak battery start. I did the adjustment, left the key on for about 20 minutes and went to go test drive. It didn't start. It obviously needed new batteries so I went down to Costco, picked up a couple Optima Red Tops (yes with the spacer to make it the correct height). Well, I hook up the driver side and a minute later, I smell something getting hot under there. I found the two posts that are right behind the intake horn and one was just cooking hot. The rubber boot was melted, and it was heating up the intake horn a lot, like untouchable. I took out the two wire to inspect for damage (like grounding on something) and they are in perfect condition. They go to these things mounted on the inner driver side fenderwell (see pics). From there two wires (still connected in pictures) go to the positive terminal on the driver side battery. Any idea what these things are and why I am having this issue?
Bill from DTT is helping me (he's been awesome thanks Bill) with the APPS setting and this issue but I don't want to call him this late .
HELP!!! :{
HELP!!! :{
