bigceltic
I just installed/hooked up my ultraguage and have it set to monitor engine load and rail pressure (FR PSI). I also display Ambient Air temp and Intake Air temp.
When at idle, in neutral, the rail pressure reading fluctuates a lot (not in sheer numbers/quantity but never stops), up and down and up and down. Load stays at 0.00 but the RP goes from a low of 6589 to a high of 6907 (was watching it this morning after 30 mi drive to work). When driving it fluctuates a lot as well up to 19007 (17000-19007), with load going slightly up and down (12%-22%) - cruise set for 60 but this is CO and the roads are not flat. Are these good numbers? Is slight fluctuation ok or is should I be looking at other tests. What is an allowable range. It is kind of annoying with the RP constantly moving - if this is not indicative of a prob, I may have to change my main display!
I checked my oil and I am not making oil, the truck idles really smoothly, starts perfectly, runs smoothly, no complaints. I have about 300 mi before I hit my 10K fuel filter change interval (3 filters: SDFK, Factory, GDP MK2). No complaints on performance at all.
On the Ambient v IAT, from what I have read, there is often a diff between the two so their divergence is no big deal (IAT often higher - I am seeing about 10-15 deg at the moment) - does IAT tell me anything useful?
Thanks in advance,
George
Thanks in advance,
George
