help w/diamond plate tool box modifications!!
Fleetguard oil filter #??
VA Boxes, who wants them??
greetings,
i need some help with a diamond plate tool box (i want to buy and modify one).
i will be hauling two motorcycles. i want to mount wheel chocks (not much stress) and tie down anchors (a lot of stress) to the tail gate facing side of the box. has anyone done this? can anyone recommend a welding shop (no truck accessory shop will do this) that will modify the box.
any help will be appreciated.
regards,
peter
1998 24v 4x4 QC, SLT, Sport, Leather, Linex, snug lid, center line wheels, Smittybilt side steps,color matched fender flares, stull grills, tow hooks----first diesel, dodge etc. i'm in love!
Are you getting a box that sits on the bed?Otherwise, there should be two real good tie down points in the bed (at least in my 96).
They may still have the rubber plugs covering them.
I've thought about lifting my toolbox up, solidly supporting the bottom, after I've attaced a couple of chains to these points so I can use them again.
"Roadrunner"-96 4X4 club cab-12v-auto-3. 54 gears-Amsoil bypass filter - all Amsoil fluids-trans filter-britebox-shelfit-DeeZee boards-Rhino liner-Rancho 5 speed shocks-Hellwig rear antisway & overload springs-Warn 12000 lb. winch-dual redtop optimas-combo gauge and trans. temp gauge in pillar mount-255/85R16 Kelly MSR tires-custom pinstriping- Walker muffler-Cummins mudflaps
i am looking for a box that will be flush or just below the bed rails. i want it to sit on the bed to maximize useable space. i want to avoid excessive holes in the bed.
anyone know of a decent welding shop in the sf bay area willing to do this kind of work?
thanks
Americana,
On my tool box I installed Stainless U-bolts facing down on the part that goes over to the bed side and they work great for tying things in(also placed on fore+aft sides of the stake pockets before installing diamondplate cap). Don't see a reason you couldn't do the same thing on the back of your box, just get some aluminum angle to bolt them through on the inside of the box to stiffen it up. I got mine from Eagle Hardware but if you want polished ones go to a good marine supply store that carrys hardware and you can buy transom eyes that are polished stainless in different sizes with polished backup plates,this would probably be stronger than welding eyes to the aluminum. Also you could bolt aluminum angles on the out side(using stainless fasteners) for your wheel chocks.
Hope this helps. HAPPY RAMMIN
Caleb
1993 LE W250 4x4 CC,Auto,3. 5's,Limited slip. Diamondplate,K&N,Egt,Boost,trans temp VDO Vision series, BD 3 1/2" Exhaust.
Preparing to B. O. M. B.
when I added my tool box there was not and i REPET NOT GOING TO BE ANY HOLES drilled into the bed of the truck I made some u clamps (ss)that go under the bed rail and bolt down throw the box to hold it in place I also add two allum. block to the box to fit into the pockets of the bed to keep the box from moving when a load is tied to it also added (ss)reinforsment inside the box at all bolt points it is always better to bolt thing in place when you are working with thin allum. and add backing to me it looks cleaner.
Originally posted by americana:
greetings,
