Well tonight I learned that you get what you pay for. I purchased a used 1998 12 valve 3500 2wd, drw, thought I practically stole it. When I bought the truck I knew that the front suspension and oil pan were replaced from an accident and that it was leaking some oil, I thought from the oil pan. Well today My mechanic for big jobs (to me such as replacing the pan) told me it was the timing case cover and that that would require removing case, gears, cam etc. Mechanic suggested I take to dealer and get opinion. Leak is from rear of cover where it meets the block at about 5 oclock position.
Question 1: Should I keep the truck or let someone else inherit the problems.
Question 2: Have any of you ever had the front case cover off, for KDP Etc. how much $ and are you happy you fixed it or having chronic problems now.
Question 3: What could cause a leak at this location, could something else bad under the cover? (my guess is accident)
Question 4: If I have it fixed will front end of motor be solid and reliable.
Sorry for the long post but this may be the difference between me owning a Cummins or not. Any advice would be appreciated.
