What's wrong with my AC? It stopped working in December, I had it recharged and all was well. For about two months. Then, took it back in had it checked, the tech said that he thinks there is a leak in the evaporator. $1500. 00 to fix. No way can I drop 1500 on a fix for ac especially when it's just a guess. So, I let it go for about six weeks. I bought a recharge kit myself, when I hooked up the pressure gauge to the low side, with the temperature being about 70 degrees, each time the compressor clicked and engaged, the pressure would go up to 25 or thirty and then drop off when the compressor stopped. Which seems to me to mean that the system has a full charge, is not leaking, and likely has some other problem. Also the the line going into the firewall to the evaporator was pretty cold, the one coming back out of the firewall was much colder. So I think that part of the system is working well enough. Just no cold air. Also, not sure if it's worth mentioning, but the truck is now in a very humid climate, not sure if that has any bearing on the functionality of the system. Any help/advice would be very much appreciated.
