Hello all, long time subscriber/reader, always found what I needed to know by reading other posts till now. This is a truly great site, by the way, I've learned a ton.
I have had two Cummins Rams prior to my current one, an 01 5 speed manual and 04 6 speed manual with just AFE intakes and Edge EZ. Both pulled my 12K fiver great with no EGT issues at all I could hold 'em to the floor with RPM'S up and never got into the danger zone.
I now have an 06 auto because the wife doesn't like rowing the gears, and I'm regretting this decision big time after pulling my fiver this weekend. The truck is stock except for AFE intake, and my EGT's are through the roof. I can't even use the power its got, which is nowhere near what I'm used to.
I have to back out of it on even small hills, overdrive off, RPM"S up, because it starts going past 1300 fast. Lower RPM's, forget about, climbs out of site in a hurry.
I live in Washington state, and I havent even hit the mountain passes yet, these were just "hills" and the temp was only 40 degrees outside.
These are the same routes I always took with my old truck set-ups, with no issues. I can't imagine adding a power box will make egt's go down, so what should I do? By the way the most boost I see is about 28 PSI, is this normal for stock truck, my others turned 35+ with Edge box.
Sorry this post is so long, any help would be greatly appreciated. Devlin
