3800 v-6 engine w/ 100k miles. Good oil changes and air filter.
Going 80 mhp down the freeway the van just stopped making power. Acc. Pedal down and the van cond\stantly decreased. Max RMP was about 3k. Coasted off the the should of the raod. Van would barely idle and if put in gear it would not go foreward and would quit. I waited about 5 minutes and then restarted the van. It gradually reved up to 2500k rpm and eventually got up to about 30mph. It drove this way for a few hundred hards and then lost all power again. Even with full throttle, the van kept decellerating until it was barely rolling. The idle was spratic this time and the engine sputtered every time I tried to nudge the accel pedal. "Service Engine Soon" light came on. Oil and transmission fluid checked-out good.
Dad-in-law towed us to an Autozone about 10 miles away using his 2 wheel car dolly. Their handheld diagnostic do-hicky said "multiple cylinder misfire", but gave no code for what component could have been causing it. He reset the code.
We towed it the remaining 50 miles home and installed a new Coil unit ($51) where all 6 spark plug wires attach. Quick test drive felt great, but the "service engine soon" light came on again. I was already 2 hours late for my best friends wedding so we jumped in the CTD and headed out. This morning my wife drove the van 40 miles away to her parents and reported all ok... until the return trip this evening. About 10 miles from her parents the van lost power and did the same thing as it did yesterday. Looks like the coil didn't work.
I replaced the plugs and air filter last year. Pretty puzzled as to what "Multiple engine cylinder misfire" means. ??? I don't think it's the timing belt, because when it was running it ran very smoothly.
I could really use some help here.
I'm thinking perhaps a bad fuel pump?, clogged fuel filter? (I use 4 oz. of Berryman B-12 Chemtool about every 4th fill-up so the fuel should be pretty clean), or possibly some other electrical component... ???? Something is making the cylinders misfire and and cause total loss of power. I really thought the coil had gone bad and was shorting out and causing the cylinders to misfire.
This is uncharted territory for me. Thanks in advance for the help.
- Ben Rumson
435-563-3396 MST
-- email address removed --
- Ben Rumson
435-563-3396 MST
