Help with a slide out for Hyd/power unit and battery storage
I am buying a Diesel Pusher and have questions
Coolest offer ever!
I need some help with a poorly designed slide out that my hydraulic power unit and batteries are stored in under my Hi-Lo trailer.
the last batteries that were used were too heavy and bent the slide on that side and the plywood is coming apart from the oil and acid. the replacement of the plywood is easy but I would like to make a better set up for the slide like a roller set up.
has anyone modified a simular set up that was work in this situation and were would I get the roller guides from?
I found everything i needed at Loews and built a new drawer slider system with 4 heavyduty drawer bearing slides and laid them horizontally instad of verticly to save room.
