Archived Help with codes
Archived brake combination valve or rubber lines
Archived 1997 NV4500 4x4 transmission issues (clutch)
Hey all, I got a check engine light last night on my way home.
I got a 1693 and a 0253. I know the one is a companion code, but what is the 0253? I did a search and I found the generic description, but that's no help. Also, all the searches came back with people that had similar codes.
I recently hooked up the wire to my DDUFM. Could I have a bad ground, as I did move it to the intake horn? Should I be worried about this code?
I have 12 psi idle and less than 5 at WOT, box on kill. There is a slight bucking but I was guessing this was due to running out of fuel. And yes, I am addressing the fuel issue.
Thoughts? Ideas?
Thanks!!
Dave
