Help with codes ??
Fuel leak!
Exhaust brake goes on tomorrow...Info please
Greetings folks, today I noticed the check engine light was on. Everything is running great. Codes were:
0480
0514
I understand that these are for fan circuit and battery temp sensor.
Any ideas what the problem is ? I do runn a cool down timer, bub didn't use it today...
Also, how do I re-set ?
I had to put a jumper in my fuse box to get rid of the fan code. The ECM was calling for the fan to engage but it didn't have power so it throws a code. Not sur eon the other one. Are you using Howard's Cool-Down Timer?
Was thinking of doing the battery disconnect reset procedure, but the engine light is out today ? I do have howards cool down timer, and have been using it for almost 2 years with no trouble. I did drive through some real bad Tstorms the other day, and as a result hit some narly puddles at speed. Maybe something got wet ?
Do you have the fan jumper installed in the fuse box? If not you may have had the fan code for a long time as it does not throw a check engine light. Then maybe the puddle tripped something.
