My engine recently ingested a washer and I had to do a full rebuild. Not thinking too clearly I put in SO pistons in my HO engine. I have been doing a little research and the only real difference in the pistons is the bowl is approximately . 080" larger in diameter. The problem is that my compression is really low. I have a . 020 over head gasket, the block was decked . 007. Also note I went . 020 over on the pistons to allow a clean bore from the damage. I did a little math on this but don't seem have have all the variables.
A little help please.
Dennis
Dennis
