OK, I got my notice for a smog check and I went out and did the 3 x's on key check for codes. I got the 0237 & the 1693, of course. So I removed the XZT+ and put the factory air box back in, removed the safety wire from the wastegate, disconnected the batteries and left the ignition switch on over night. I still have the codes and the truck runs fine but the fuel economy on the overhead liar is atrocious. When it used to lie at about 19. 1 it now struggles to get to 17.
My question is this. Is the MAPS sensor bad? I have removed the connections at the MAPS and the ECU and recoated everything with dielectric grease and made sure that the connections are as good as they can be. Truck has 101K. I will be removing the MAPS and the IATS tomorrow to clean and reinstall. Any suggestions here on something that I am missing or should check?
As always, I appreciate any help that is offered.
