I changed out the front brakepads and overflowed some of the brake fluid. After starting up, pumping the pedal the brake and abs lights went off, then they came back on and the odometer showed the no bus message. I tried the instrument panel self diagnostic test and got 900 920 940 and 950. Where is the CCD data Bus? How do I reflash the PCM software? I turned the ignition key on and off three times and got the codes P 1693 and P 1694. Where is the companion engine control module? I don't see where any of the brake fluid got into any wiring. Looking at the fuses marked engine- they're all good. Truck seems to run fine-but I have no gauges whatsoever.
2001 (early) 2500 2wd long bed quad 94,675 mi. Now and then while driving the gauges all come on but the MIL light stays on. Please help.
