Details here: TDR Privileges
I have a 05 ram2500 4x4 with 5. 9L. . no mods. . I think i have a small diesel leak that is showing up between back of engine and transmission. . Everything is dry up on rail and all injector lines and fittings dry. Is their a return line on back of head?
Well, i just checked again, now I think it is oil, pulled converter access cover and has black oil in side building up. . checked up at back of head and it is dry. well, must be rear main seal leaking. ):
The draft tube can make a slobbery mess back there (air currents blow oil all over that area) as will a leak from where the crankcase vent filter is (under the valve cover).
