My son has a 1961 Allis Chalmers with diesel engine. Needing to replace the exhaust pipe and muffler, he proceeded to remove the four bolts that hold the pipe flange to the manifold. Three of the bolts bound at about the half way point during removal and broke off.
To make matters worse the bolt extractors he used to attempt to fully remove the bolts also broke, while imbedded in the bolts. There does not appear to be any corrosion when looking into the bolt holes where the top threads are visible. It was my suggestion that he should have heated the manifold with a torch, prior to attempting to remove the bolts. The question now is what approach should be used to rectify the problem. Removing the entire manifold and taking it to a machine shop came to mind. But in the Deming / Las Cruses, New Mexico area, unable to find a machine shop that will touch the job, even if the manifold is brought in.
Any suggestions would be appreciated.
Many thanks in advance.
Hugh
Hugh
