I suggest the other TDC so the key is at the top. The new pump will go in correctly with the keyway, and lining up the marker line on the outer foot with the one on the gear housing. Those who want more timing, rotate the pump so the top of it is closer to the engine. Just a little, please, if you don't have a way to measure the timing.
