Engine/Transmission (1998.5 - 2002) Help With Isspro Isolator ????
2nd Gen Non-Engine/Transmission spare tire
Engine/Transmission (1998.5 - 2002) in-tank pump removal help
Question it says to fill and bleed air out with coolant. Would that be antifreeze. 2. Is all this bleeding process needed? Or can you hook it all up and just cycle the key a few times thank you for help on my fuel gauge install and any other helpful hints would be great. i bought the kit from genos thanks andy :)
If you have the same isolator as mine, fill the gauge side with antifreeze to within two threads from the top. You shouldn't have to bleed it if your gauge is within 6 ft of the isolator. I mounted mine horizontally on the firewall and your cleanout screw should be facing down. I ran a braided stainless steel hose from my fuel source to the bottom of the isolator. Hope this helps.
