Okey0 said:
if i understand correctly, a larger diameter tire lowers your ratio. In other words, if I have 3. 73 gears, a taller tire could lower it to 3. 5. the lower ratio would mean that at the same speed, the engine is at a lower rpm, correct? If this is the case, why does everyone say they notice a drop in mpg with larger tires?
Yes, taller tires will lower engine RPM, as it makes your overall gearing "taller" (lower numerically).
The drop in mpg is due to the fact that larger tires have much more rolling resistance, and take more power to turn. This usually offsets any increase in mpg you may get from taller gearing.
Besides, diesels will not get better mpg just from taller gearing, unlike most gasoline-powered vehicles. Gas engines have a very narrow range of air-fuel ratios, so when you lower RPM, the amount of fuel used goes down as well.
Diesels can very air-fuel ratios substantially. Thus, when you put taller gears in, the engine compensates (since it has to work harder) by making the fuel richer. The net result is no increase in MPG due just to gearing.
Now add back in the negative effect on mpg that larger tires have and it's pretty easy to see why larger tires almost always give you lower MPG on a CTD.
Oh-- and to calculate the effect of tire size on gearing or RPM, just do this:
(new tire revs/mile)/(old tire revs/mile) X existing gear ratio or RPM.
For example, say you switch from 265 tire that's 655 revs/mile to a 285 tire that's 622 revs/mile. If you currently have 2000rpm at 72mph, then your new rpm would be (622/655)*2000= 1899 rpm (basically 1900rpm).
Same goes for gearing. (622/655)*3. 55= 3. 37 as your new gear ratio.
A 315 tire usually has 599 revs/mile. So swapping from a 265 tire to a 315 would change gearing and rpm this way:
(599/655)*2000= 1830 rpm. You went from 2000rpm to 1830rpm cruising at 72mph.
Gearing went from 3. 55 to (599/655)*3. 55= 3. 25 effective gear ratio.
Hope this helps.
Justin
