I just got my truck back from the dealership last night. They had too replace the evap. unit in the dash cause the a/c was not working correctly.
First thing I notice is that the door panels have been damaged by the tech when they were removing the dash, but the dealer is coughing up new door panels and will be putting them in here in the next few days.
Then later that evening I notice that my over cab lights are not working. After closer investigation here are all the lights that are not working since I got it from the dealer.
1. over cab lights (all 5)
2. front passenger side clearance light ( parking light)
3. rear passanger side clearance light (taillight)
4. passenger side rear bumper license plate light.
So basically the lights that have their wiring harness on the passenger side is not working. But to make it more confusing maybe is the fact that the passenger side headlamp and brake lamps are working fine. And with all this the lamp out indicator is not coming on on the dash.
Being that all the lights that are not workinig are all powered by the same thing, the parking or clearance circuit on the truck for the passenger side what would you guess is the problem?
Is there a seperate fuse for the cleareance lights from passenger side and from driver side that could have been popped?
Or is there a plug under the dash somewhere that the tech did not hook up?
What do ya'll think could be the problem?
I would prefer to fix it myself if it is easy enough so that I do not have to go through the hassle of leaving my truck at the dealersip again.
Thanks for your help ya'll,
Vern
Vern
