help with PE & EZ wiring.
Antifreeze
eth and power upgrades
I just received my EZ from snowman, I appreciate that, sir.
Does anyone know the way to wire the EZ and the PE up in series to run both boxes together?
It arrived late yesterday and it's still dark outside here now so I thought I would ask before going out with a flashlight to wire the 2 boxes together.
Thanks.
David
aka Marbleman
Im glad you got it in time. I wish i knew for sure if it mattered which map connector went first,the ez's or the PE's. I would just try it with the EZ's closest to the map sensor,if you get no answers here.
Thanks SnowMan,
Your help is greatly appreciated.
I got the EZ installed, along with the PE and it works great!!! Much better response off the line and it has very little smoke.
Next stop 275's and 4" and that should hold me for... ... ... ... ..... ?
David
Marbleman
Anyone else I knew that stacked two boxes like this (including me) attached the map plug from the fueling box to the map sensor first, then added the plug from the timing box after the fuel box. The fueling box adds fuel depending on high boost(power demand), so you don't want to clip the boost sensor voltage ahead of the fueling box, which is all the timing box is doing.
