I have a 95 3/4 ton 410 rearend, 65000 miles automatic.
Have had the truck for a year but only ran 2 tanks of fuel through it as I bought it to pull a fifth wheel we were going to buy as I neared retitriment. New fuel,air, and oil filters.
Towed it home yesterday, 30 ft fifth wheel 7700#. Started on the trip home brought it up to around 45 on the freeway then turned off the O/D light took it up to 65 at 2100 RPM pulled beautiful. Several short and long inclines, never kicked out of O/D or lost more then 150 RPM.
Off of freeway to a 55mph road with hills, shifted manually off of O/D. Could not get above 54 MPH at 2500 RPM. Throttle to the floor. turned O/D back on manually, went down to 2100 and stayed there for a few seconds and then down to 1700 RPM and ran smooth.
Should i be able to do more then 54 out of O/D. What was the double shiffting when i shifted back into O/D. Was it first the T/C locking up and then the O/D. Sure am confused as it is not what I expected from this truck. Any suggestions will be appreciated.
I have ordered gauges but DIS is having problems getting the 3 hole pillar.
