My 99 (see sig) sways, bobs and weaves to the point of being scary when pulling a trailer. My 91 250 was solid as a rock. A month ago I pulled a 26ft enclosed race trailer w/ 4 quads and a dune buggy in it. In 600mi I probably hit the trailer brakes over a dozen times to get the thing straighten out.
We hooked the same setup to a 1/2 ton Chevy and he hammer down the road at 75mph no problem. Embarrassing as hell. How can that be?
I have no idea of the trailer or tongue weight but this is not the first time I've had problems.
Every substantial trailer I've towed has done this to some degree.
Towing my 18ft enclosed w/ just the dune buggy does the same thing but on a less severe level.
Cranking the tire pressures to max seems to help but it's still not confidence inspiring. The tires are 285/75R/16 Mastercraft Courser C/T's on the stock chrome wheels. Is it possible the cheap tires are a problem? They are load range D. If I keep the speed down around 60 or so it's tolerable but still unnerving.
It also seems to squat more than I think it should, definitely more than the 91 did.
Comments? Suggestions?
