help with transmission gauge
$250 = 267 Hp
transmission annoying question!
You want to tap into the torque converter out line. That is the forward most line leaving the transmission. It is located on the drivers side and runs under the transmission and up to the fluid/fluid heat exchanger on the side of the engine near the exhaust manifold.
Dave
Order a replacement trans line for the hot fluid side with a fitting for the trans temp sending unit. I got mine from Parker Motors In canada. The only phone number I have is 250-493-0524. I paided around $55. 00 And had it in a couple days. It fit like a glove. Paul
PBayer is right.
Go with the factory line. I tried an after market one, I won't say which one to avoid bad rapping a company for a single bad idea. Teh factory one has to be better.
I've been chasing a leak for a few months. I think I finally got it fixed the other day. Too much brass
Avoid the hassle. Be ready with about 2 quarts of fluid as it drips out until you get the new line in.
IMHO
The information I gave above is not an aftermarket piece. It was from dodge and is working fine. Guess you could get one from a local dealer in the US. Paul
