2014 3500, I replaced the actuator last december with a City Diesel unit... has worked great till last week when I could only get 8psi of boost and nearly zero braking... strange thing here is that I turned the ignition off and restarted and every thing was fine... 29psi and 80+ braking ... went about a week and ran great then Sat it did the same thing no boost/braking turn it off start back up gets me full boost/braking.... wondering if there is a sensor that might be going bad, it's not acting like it did when the 1st actuator went bad, I could not get it to reset... sounds more like an electronic problem instead of a mechanical vane stuck problem in the turbo... any ideas???
