The ashtray light is fed by two wires - an orange and then a black with brown stripe. My FP gauge has a wire for dimmer control.
(1st question): which of those two ashtray light wires should I tap into for dimmer?
(2nd question): can I do power AND ground from cigarette lighter wires red and black, or should I ground somewhere else?
Here’s what I’m doing if you want more detail or have any better suggestions.
I’m installing a Nordskog fuel pressure gauge that has four wires. I’m installing it under the cigarette lighter at the bottom edge of the dash. The four wires on the gauge are:
Red - 12Volt, was going to hook to cig lighter red
Black – Ground, was going to hook to cig lighter black
Purple – Dimmer, dims the gauge when receives 12V
Orange – Sender
Got any better ideas?
Thanks
Orange – Sender
Thanks
