Help with wiring
CTD girl's new truck
Bak industries Tonneau cover
Where would be the best place to splice into an ignition hot wire (the fuse adaptor that came with the painless wiring kit doesn't work)? Also installing some hella FF-75 driving lights and trying to figure out which is the headlight wire to t-tap into to drive the relay. thanks ahead of time.
Most people use the cigarette lighter. I used the heater controls signal wire. Either way.
Are you installing the auxilliary fuseblock?
As far as the headlight wire, just tap into the headlight switch...
-Ryan
