hi
I have a 91. 5 truck and about 3 months ago the stock steering gear box started to make the truck want to wander to the right so naturaly i would hold pressure in the oposite direction, but then after a week or so of that the truck started to fight back, I would be driving down the road holding steady pressure to the left (to counter steer the pull) and sudenly the truck would dart violently to the left and then when i would counter steer back to the right it would do the same in that direction and soo on after about 10 seconds or so, i would be able to regain control of the vehicle and it would go back to its steady pull. the truck would periodically do this every once in a while increacingly until it was at the point were it did it all the time.
***All this happend in roughly week in a half***
To fix the problem i put a PSC gear box on, along with a borgson steering shaft this solved the problem 100%. I had it on for about 2 mounth when the exact same thing happened AGAIN
#@$%! i dont know what to do. could there be a problem with the power steering pump that is destroying my gear box. or by some freak chance could the problem be that I ended up with 2 misfuntioning gear boxes in arrow with the same thing wrong with them
Any ideas are apprecated!!! Thanks
(Doug's son) Dan
(Doug's son) Dan
