Details here: TDR Privileges
I've been working on hooking up my bully air horns. I need a 20amp key on power supply for the compessor. All my fuses are doubled up I just don't have room in the fuse box. Anyone know an easy spot to hook up to?? Any help would be great. Thanks in advance!!
Run off the iginition acc wire (one that runs radio, not sure of color off hand) and do yourself a favor and install a relay with that feed to trigger it. That's the way I have my setup. You can then run any size/guage wire for any accessory and fuse setup. The horns will not be your only accessory .
