Moved to 911 cause I need help! Anyone???
I just got my 6-speed in last night and it's got problems. It was one I got that was lightly used as a Dodge test trany. It looked like it had very few miles on it and not much rust on the case. It's an '02 version as far as I can tell. Anyway compared to the other two I got, the input shaft seemed quite loose and would even hit on the housing around it. The other two would not do this. So I went ahead and added some shims to tighten up the main shaft a bit. Well now when I drove it for the first time it seems to be binding (shudders) in all gears except direct (5th). The more load I put on it the worse it is. It is the worst in 2nd and 3rd I think. Is there anyone here who can tell me if this might be caused by the main shaft being too tight or might I have another problem? I also added . 003 to the counter shaft, which left it with a tiny amount of end play. I am guessing on all this because I don't have all the attachments to hook up a dial indicator and plus I would have to pull the rear housing off to check it. The specs call for . 002-. 006 end play on both shafts. I'm FREAKING out here and hope I have not killed something already in my 20 miles of testing. I wish I had the money to just have an expert set it up and make sure all is well. Oh it shifts great!! This is what I was worried about and now that is fine and I have something else going on. There has to be a trany expert on here so if you see this please speak up!!
Edit: As I think back on this thing before I did anything to it, it was harder to turn then the other two. If I held the output shaft when in neutral it was even stiffer, which is normal to some extent but seemed almost excesive. I figured that since it was so new that maybe it was just not as broke in as the others and that may still be the case. Help!
Thanks,
Mark
Thanks,
Mark
