HELP!!!!
How much back pressure can I run w/60# springs?
Injector Tube Puller
Ok, I have a consistance pull to the right "alignment". Will this set up work?
Left Wheel Right Wheel
caster 3. 2 3. 5
cross caster -. 3
camber -. 10 -. 10
cross camber 0. 0
This is what I pull off of the TDR site. Please,please help. This cost is out of my pocket.
Thanks
Frank
01 White, Quad Cab,Short Box ,Sport SLT+,5 speed,4X4,line-x ,Nerf bars,fiberglass tonneau cover
Ok, a couple of questions, why is it out of pocket on a brand new truck? Are you over mileage already? I took my truck to the dealer for exactly that problem and got it aligned twice for free, and a new steering box was installed.
First, I believe those specs will get you what you want, assuming all other factors are nullified, such as the steering box etc.
Second, I suggest you have them look at the steering for worn track bar, and steering box. On all years preceding '01, these have been problem areas.
Third, have em take a look and be sure that you do not have the dreaded brake pull.
Thats all I can think of off the top of my head that could be a problem.
Y2K 2500 QC Sport 4x4 LWB
72 Dart 340
89 LeBaron GTC 2. 2 TI
They (castle rock chrysler) tried to align twice(still pulls). They say its within specs. Milage is 4150. still under warantee.
They have replaced the stearing box already. That seemed to help alot. But I still have loose stearing (I think because of the alignment).
Thanks
Frank
