This is a coppy of the post I put on the 94-98 12valve forum.
I have a '96 Doge Cummins 5. 9 that is going to repower my IH pick up. I have an Advanced Adaptors Ranger gear splitter over drive feeding into a GM SM 420 truck 4 speed and a rear axel ratio and 235/85r16 tires that will give 60 mph at 1780 rpm. This drive line is maybe somewhat delicate to make more power with but if I use the power mostly in direct in the gear boxes and am careful I should still be able to enjoy some upgrading and if I do break something I can upgrade that. This is not a towing rig. I guess I'm going down the "addiction to power" slippery slope!
I would like to try to buy things that will work for me now and also if I decide to go further. The first thing that looks good is a 3K GSK. Then a cam plate. Then it looks like to use much power over 2500 rpm I might need to go with a bigger turbine housing like the 14 cm. I still want to keep bottom end torque. I think I don't want to go over 675 lb-ft of torque yet... . But I would like to keep some of that torque to the higher rpms that's why I thought of a bigger turbine housing and GSK kit. By the way I already have a Pyrometer and boost gauge and an intercooler from a '92 dodge Cummins on the truck. It has a Nissan turbo diesel now that is coming out. I was running that little 3. 3 liter prechamber engine with 18 psi of boost and 800 deg egt after turbo egt. max but the pistons don't hold up. The compression ratio is 20. 5 - 1 and the pistons crack that's why I am installing the 5. 9. I have and will use a intercooler out of a Ford Power Stroke and it is allot bigger than the one that's in there now! Also I will be doing my own exhaust in 3. 5"- 4" strait pipe. I am considering changing axel ratio from 3. 73 to 3. 08 to even lower my highway rpm to take advantage of fuel economy. But I do want the option of putting it in direct and really accelerating.
I was considering buying a South Bend Clutch which they said would really hold to some serious power and it costs too. A stock GM diesel clutch will hold up to 675 lb-ft before it slips and I thought that the clutch slip might not be such a bad idea if it saves me from twisting off the input shaft on the transmission!
I am not sure yet whether the engine I have was an auto or stick engine but will find out soon. Could that affect whether I need to replace the injectors or not? I was hopping I could hold off on that till later.
I would be very happy to have any ideas you have especially as to turbine housing upgrades and potential hp possible with these upgrades or others I should consider.
Thank you,
Treven.
Thank you,
Treven.
