Sorry about the response but it could be because the subject has already been discussed. A lot.
Good luck with the TH - guys seem to be happy with it. I've just been lucky that after the first failure and a repair by the dealer, I've had no further problems other than a persistent rattle they left me.
But hey, speaking of making it in the quarterly,. . I got two pics "published" in the most recent one! Oo.![]()
Thanks for the response P Dog. I will look for you in my morning pre-shower reading of the TDR.I will hit the 1/4 Million mile mark next week. Can't complain as I am not walking 60 miles to work. My switch wiggle trick lasted only one time-one way on the commute.
I used search but haven't found a troubleshooting post for diagnosing the problem that includes the controls. I remember a site that has all of the wiring connector diagrams and will start with jumping out the switch connectors to eliminate it first. Hand warmers in the toes of the boots until then!![]()
You could have a bad actuator, they are electric on my '06. I think the vacuum controls stopped with the 2nd gens.
There should be something in the service manual as far as a test. I know that some need to be reset so that the operating range of the actuator / door unit syncs with the command given by the heater controls.
I do not have my service CD with me right now or I would take a look for you. There has been so much door trouble that a bad actuator might get overlooked at first read.
Mike.
Mike.
Do you have duel heat control on your system? If so you will only be able to use the mode 1 and recirc door from Heater Treater. I ordered all four and ended up sending two back.
Mike.
