I think someone might find this one usefull...
A little background first.
This summer my lift and pusher pumps died a slow death. They ended up with 0 Psi @ idle. Back then the FASS was on backorder, then the time to ship it... I had to do something in order to keep my truck on the road till the FASS would have arrived.
The only fuel pump I had handy would deliver a pressure of 30 Psi.
( That's what the MFR declared. )
What the heck, I use this one for a while!
Once everything was installed I discovered that this pump would run 55 Psi @ idle... . Oh well it was installed, I figured I could take it for a spin anyway.
(I found out later that the FP under WOT would stay arround 35Psi. )
Hello! There was a very noticeable performance gain mainly form the mid to high RPM range.
I've driven the truck for about 1K miles with this "lift pump" till the FASS arrived. I have noticed no ill side effects during that time!
You know with all the hype about too high or too low fuel pressure to the VP I didn't feel comfortable and in the FASS went.
Now to the point.
For you guys with "extreme" trucks. What about such a pump in parallel to the normal fuel pump(s)? You'd need only a couple of check valves in order to hook up the two systems together... At the track / Dyno whatever... with the flip of a switch...
Thought's?
Marco
Now to the point.
Thought's?
Marco
