hey guys there is a pull in Ripon Ca
Southern Alberta BOMBers
South Texas Get Together
OK the pulling season starts next weekend in Ripon Ca, it on 99 toward Medesto. I don't have all the details yet only that its going to be happening #ad
Its just in time I got my truck rolling today with the auto in place #ad
I can't wait. I hope to see some of you guys there.
Adam
Adam,
I guess I haven't been paying attention (as usual) so the question is what transmission did you have, and what mods are done to this one?
Arlan
Yea BABY pulling season again we will have one of the big DEERE'S there the other one is still getting a major retrofit but it will be done soon also we will be releasing a mad minni this year also I think if we get it done, hope to see alot of you there either Adam or I will post the next pulls as the year goes I don't have the full schedule yet but we should soon
2001. 5 ETH/DEE 4x4, DRW QC DD3's, EZ, HX40 machined out for more flow, Custom 4" exhaust turbo back staight pipe with 5" chrome tip in front of rear tires,spa's, mcleod clutch, fuel lines,mag hytech rear end cover,psycotty air system,relocated blow by bottle,Lucerix power heated mirrors,more to come
Will this be a Sat, Sun or Sat and Sun thing and I would like to try and drive down and be a spectator for the event. Let me know if you find out anymore info.
Thanks
2001 2500 QC 4X2 Flame Red Clear Coat
Magalia Ram
it will be a sat only event I will post srart times this week and where it is BRING ON THE SMOKE
I wish I knew how to put my telare videos up of the tractors and my truck, even Piers old truck.
I now have the same transmission Piers had, auto with their tc. I hope it holds up better than all the nv 4500's I had. I think I will be better for pulling if it hold up. I can go through the gears instead of slipping the clutch to end up in kindof the right gear.
Is this at a fair grounds? Anyone with some rough directions from Hwy 99 SB from Sac. ? I know where Ripon is I just need the location of the pulls.
Magalia Ram
Okay here's the scoop the pull is in Ripon Ca at 2:00 Pm Saturday the 17th of march. Directions are as follows, HWY 99 north or south depending on your location to JACK TONE RD off ramp, go West to CANAL BLVD, turn Left on Canal continue it will curve to the right continue straight there will be a vacant lot on your right that is the place. (209)652-5303 or (209)613-9675 these are my phone numbers in case anyone gets lost, the pull will end about 5:30 or 6:00 followed by a distruction derby until 10:00 Pm, anyone who wants to pull will be able to as long as you get signed in first, I recommend getting there early if you want to pull it can be kind of a zoo at times. Hopeto see a strong showing from the Dodge boy there may be a few Fords around in need of an attitude adjustment. WIZ1
I'm a cummins through Sacto between 10:30 and 11AM on my way to the pulls. I won't be a participant but I will be there to support all the Rams that will be scattering dirt on the Pherds #ad
Magalia Ram
Doing my taxes today I noticed that I got Diesel at the flying J in Ripon CA twice on the way to and back from Shaver Lake.
Is the overpassed fixed yet? #ad
Adam took secong place in his class, just 14" short of first place.
The smoker tractor pulled the sled out the gate with the weight all the way forward and the wheels locked!
Nowel/Performance Diesel
Well three days of wrenching on the tractors till 4:00 in the am then going to work at 6:00 was worth it both tractors ran well the John Deere had a little glitch though injection pump stuck wide open driver had to hit the emergency shutdown swith the tractor finnally stopped 5 feet away from a piece of equipment thats what happens when the sled can't stop you and the engine won't shut down I will be tearing down that pump next week to fix it see Ya it was good to see everyone there Willyslover, Hvac,my6eatsv8's,cumminzpwr,BPine,and everyone else thanks for comming the next pull is at Cal Poly we will be bringing a totally new engine and turbo set up to that one it should be hard to stop that tractor I will post info when the pull gets closer WIZ1
Here you go Adam getting a little Smoke... .
Thought you might like to see this one Adam.
Magalia Ram
[This message has been edited by M_Pulling (edited 03-19-2001). ]
