HF....2m/440....CB.....
Used Tires - Yes or No?
Door panel clips-01 Ram
How many of you guys have all three rigs mounted in your CTD..... If so could you please post some pics how you did it. I am trying to figure out a way to get them to all fit in there and look good.
Jason
No... ..... I have an Alinco HF rig..... A Kenwood TM-V7A (VHF/UHF) and a Texas Ranger CB... . Was curious if anyone had a setup with all three mounted somehow in their CTD (Not specifically those models)..... My plan is to mount all 3 in there somehow but not sure how to do it.
Jason
i only have a 2m radio right now in mine, but i mounted it in the storage hole in the lower dash. it fit real well and looks good there too. i saw a ram the other day with some type of HF rig in it... his antenna install was on an aluminum tool box in the bed. looked real good.
N3PSS
-jeremy
not real sure how to explain it, maybe your truck doesn't have it, but to the right of the ash tray in front of the gear shift lever and to the left of the glovebox, mine has a hole in the dash that is meant to tuck stuff in so i tucked my 2m rig in there. i am gonna drill out the bottom of it and run the coax and power leads up under the dash, just haven't had time to do so yet.
-jeremy
Sorry, Yes I have that but my 2m/440 will not fit in there... . The hole is way to small..... Are you putting you Handheld iin there? I have a kenwood TM-V7A and it is about 5 inches wide... ... . Even my 2m Yaseau wont fit in there... ... ...
Jason
