The ball joints were weak on all cummins rams since 1994 i think. will my 2009 be as bad or is there improvements in the design, whats the best aftermarket ball joint for an 09? thanks
you need ball joints allready... my 06 is still tight... what are people doing with these trucks????
Doesn't really answer if the ball joints on a 2009 have been upgraded from your 2003. Changes cost money so if it ain't broke they don't fix it. That they felt compelled to make "improvements" speaks volumes about that POS AAM axle.Ram Engineer said:Guest - question on Ram front axles - 2500/3500 front axles had a number of upgrades in 2007, 2010, and 2012 model years; focusing on a number of specific improvements such as knuckles, ball joints, and seals. The Ram team has also increased the durability test length by 50% to make sure the improvements work. Again, the goal is to be best-in-class durability for these systems.
thanks guys, are the ball joints the same on an 2009 as a 2003?
I've tried them all (almost). OEM, Moog, XRF and Now Carlis which are rattling at only 40K. I have 315K on the truck and it sees improved off road use less than 1. 5% of the time. I guess I'll try Dynatracs once I decide I can't take more rattling and or tire wear from my Carlis. I've become adept at changing them but it is a hassle nonetheless. I am still on my original hub bearing btw. I force fresh grease through the bearings via the abs hole every time I mess with the brakes, ball joints or axle ujoints.
